HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 9074
Avoiding blackening during stainless steel welding
What is the best way to avoid blackening of stainless steel surface during welding?
Vish.SFortuna Associates - Bangalore, India
Carbide precipitation occurs when stainless steel is heated to 1600 degrees. That is the separation of the chrome from the ferrite grains. In the normal welding process the process reverses upon quenching. If the metal cools too slowly the process will not reverse and the stainless will turn black. It will also rust. Try a lower welding temperature or faster travel speed or both.
John Rendleman- Grand Tower, Illinois, U.S.A.
