finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 9047
Testing Specs for Alodined Parts
Dear Sir:
We are having problems with subcontractors doing alodining and anodizing. I would be grateful if you could spell out the typical test criteria needed to perform on test samples that are sent out for alodining or anodising with our batches of products. When the items return we want to do testing so we know what the products quality is like.
Secondly what is the duration of time that an item should spend in the alodine bath and could you please tell me if there is a generic spec that spells this out.
BRIAN TRIBELHORN
- Stellenbosch (Cape town), South Africa
You need to be more specific in your request, as there are several diferent types of anodizing, and alodining..each with different requirements. Your best bet would be to specify to your coater the spec (here in the USA, it would be an ASTM, or MIL spec) that they would need to meet. Each of these specs are availaile off the web (you may need to purchace the ASTM spec and the accompaning testing specs). Your countries specifications may vary from the USA versions.
Marc Green
anodizer - Boise, Idaho
