Letter 9030
"Secret" behind
"honing"?!
What is there in "honing"? We are a leading manufacturer of DOM
tubings in India and exporting world wide.
Recently we started manufacturing tubings suitable for hydraulic
cylinder application.
Some of the customers say they can use the tubes as such provided
the id surface finish is 0.60 RA max in micron scale and meeting the
H-9 tol.but some of the other customers feel "honing" is a must.
We don't understand the reason behind this. Is honing carried out
only to improve the surface finish and dimensional tol or anything
else is there?
Can anyone help on this matter?
C.K.Sekar
- Chennai, Tamil nadu, India
Sir,
For what its worth , size control and final rms finish of the part
is operator dependant , if for example an operator were honing a
cylinder bore, and was "overstroking" the work he would creat a
venturi shape. If the same operator were to "understroke" the work,
he would creat a barrel shape since the stone are spending more time
in the middle of the work. it is also possible to get ta taper with
still another "stroke" of the work. This same thing can happen in od
honing, with variations in stroking technique the operator can create
straight , convex, and concave shapes, as for the final finish , the
operator may choose a corse stone with large stock removal in mind
then switch to a finer stone that will meet the specifications of the
print.
MY thought is ... if your tube "out of the box":
1. meets the rms requirement (which will be important for the
backup rings and seals, especially in high pressure systems)
2. meets parallel requirement
I see no apparent need for the hone.
Brad Sawyers
- Racine, WI
DEAR MR. BRAD SAWYERS,
THANKS A LOT FOR YOUR FEEDBACK ON "HONING". ACTUALLY WE HAVE
ANOTHER DOUBT NEEDS TO BE CLARIFIED. NORMALLY THE TUBES ARE
SUB-CRITICALLY ANNEALED TO RELIEVE THE INTERNAL STRESSES BEFORE
HONING. BUT TO AVOID HONING THE TUBES WILL BE SUPPLIED IN "AS DRAWN"
CONDITION WITH INTERNAL STRESSES. DO YOU THINK THIS MAY "AFFECT"THE
PERFORMANCE?
LET ME THANK YOU IN ADVANCE FOR YOUR KIND ATTENTION ON THIS.....
C.K.Sekar
- CHENNAI, TAMILNADU, INDIA
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
