HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 9027
Hot dip galvanized vs. standard zinc plated in 95% humidity 60 degree constant temp.
I am providing steel conduit and hardware to be installed in a freight tunnel system in Chicago. Several of our components are simply zinc plated. I need to provide some information on the lifecycle of Zinc plating in that tunnel environment, which is reported to be 95% humidity at 60 degrees farenheit constant. Is there a corrosion resistance chart available that I could use for reference.
Steve HickernellTVC Communications Inc - Wadsworth, Ohio, USA
