HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 9024
Removing paint from motorcycle rims
I have a set of painted motorcyle rims that I want to polish but, it seems that the paint on the rims is very difficult to get off. I have tried airplane stripper and other such items but to no avail, I also tried to sand them which works but is a long and tedeous process. Is there some sort of chemical that I can use to get this paint off.
Miles Brown- Newark, NJ
I ran into the same problem with my rims and tried the same strippers, and sanding would take a life time for all of them. I tried sand blasting with sand and it left a pitting that also needed sanding out. I finally ended up sandblasting with glassbeed that left the surface smooth before I polished it out.
Nathan Mortenson- Pacifica, California, USA
I have just stripped the outer rims on my Kawaski and I used a 3M stripping tool that attaches to a electric drill. It removed the paint easy and did not mark the alloy.
Bernard Harrison- New Zealand
Try sand blasting it. It will take off all layers of the paint and also take off rust too.
Preston Tucker- Marietta, GA, USA
I've done my GXSR750 and several of my friends' bikes. It's a pain but I can almost make look chrome. have to see to believe it. I'll wash a wheel off and send you a pic. So... get a large can of aircraft stripper [linked by editor to product info at Amazon]; it's some nasty stuff so make sure to get a chemical resistant protective gloves [linked by editor to product info at Amazon] b/c the stuff will burn your skin. Follow the directions and you'll have a raw rim, Only do the lip of the rim b/c the spokes have a rough finish and it looks bad. Once it's COMPLETLY rid of powder coat. Use very clean,soft cloths, Mother's Aluminum Polish [linked by editor to product info at Amazon], and a-lot of rubbing.
David Jones- Frisco, Texas
HI, I WAS WONDERING WHAT IS THE EASIEST AND FASTEST WAY TO REMOVE THE PAINT OFF OF MY MOTORCYCLE RIMS. I READ PAINT STRIPPER, AND AIRPLANE STRIPPER, AND THAT THERE ARE 3 DIFFERENT TYPES OF STIPPERS. LIQUID, PASTE AND GEL. SO WHICH SHOULD I TRY.
ZACH CHAUDHRYSTUDENT - TUCSON, Arizona
