Letter 8205 Surface protection for aluminum from deionized water+ I am looking for a surface finish to put on aluminum that will protect it from deionized water. Joe Solloch
+ There are a few different ways to protect the aluminum. You could use a chemical conversion such as a gold irridite, anodize it, anodize with teflon impregnation, anodize then teflon topcoat it , or just teflon it. Josh Sonju
+ Joe, Everbrite Protective Coating is an easy to apply, non conductive, clear coating that will protect the aluminum from deionized water as well as U.V., salt air and other damaging elements. It can be sprayed on, dipped or simply wiped on. The dry film is thin and will remain flexible. Hope this helps, Teresa Sedmak
Dear Reader: please choose what you want to do.
Save
