Letter 8075
Conductivity - Galvanized /
Galvanealed
I am a custom job shop, primary product is cabinet and case work
for the telecom industry. We have an application for a client
requesting galvanealed or galvanized material. I understand that one
is more accepting of paint finishing while the other is not.
My question is do both materials carry the same conductivity
charastictics? Are they both conductive? I always thought they were
but I am told otherwise.
Michael Lozy
- Warwick, RI, USA
Galvanneal is merely galvanized steel which has been annealled.
The annealling furnace is downstream, from the zinc bath. Galvanneal
is easier to paint. The surface is a smooth, dull grey. Usually, it
is lightly oiled or even dry.
Galvanize sheets have a bright zinc finish (like garbage cans).
The surface is not smooth. Zinc crystals may show through the paint.
The surface is normally treated with a chromate solution which is for
rust protection. This solution prevents good paint adhesion.
Terry T. Magyar
steel - Gahanna, OH usa
The galvanneal process converts most of the zinc and some of the
iron at the substrate surface to an intermetallic iron-zinc compound.
The electrical conductivity for the intermetallic probably is not as
great as that for the zinc or iron metal. Thus, the surface
conductivity may not be as high for the galvanneal.
Larry Hanke
materials testing laboratory
Minneapolis, Minnesota
+++++--appended to existing thread by editor
What is the difference between Galvanealed, Galvanized and
pre-galvanized.
Eileen Travis
- S Attleboro, Massachusetts
Pre-galvanized means that the item in question is made by bending,
punching, and otherwise working sheet steel that was galvanized
before the working began, rather than galvanizing the item after the
other fabrication steps are completed.
Pregalvanized material is used for economy (because it is far less
labor intensive to galvanize a continuous sheet than individual
fabricated items). If it is integrated correctly into the design, the
product should be just as good as a post-galvanized item. But if the
design is not so good, there will be rusting at the edges and around
any holes because there will be no galvanizing on edges that have
been created after the galvanizing process.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Post a
question on a different
subject.
- Answer or follow-up on this
subject (in non-commercial
fashion).
