Letter 8037
Cleaning of stainless steel - medical
device implants
Technical Inquiry:
A standard process is to use ultrasonics and subsequent acid
pickling baths to remove the oxides/slag from 316L stainless steel in
a post laser cutting operations. Laser cut parts leave a highly
metallic slag and characterization shows pure metal, and various
oxides of Cr, Ni, Mo, and Fe. Xray diffraction and SEM analysis also
exhibits some glassy amorphous compounds. Hydroflouric (HF) acid is
very effective in attacking the oxides but is a major political issue
and the amorphous material requires high concentrations to remove.
I am looking for input from chemical manufacturers or consultants
who can explain the possibilities of using complexed acids such as
fluoboric or fluosilicic that are effective but less dangerous. I am
looking to understand the mechanisms of these complexes as input into
designed experimentation based on the character of the oxides. This
input would be invaluable to the medical device industry as we try to
simplify processing with major efforts towards removing sonics,
electolytic, and highly aggressive acid pickling operations.
Scott Larson
- St Paul, MN, USA
January 10, 2009
Hi,
I'm useing EP process for ss316 tubes.
The EP bath contains
- 40% H3PO4 (85%)
- 50% Glycerol
- 10% H20
I close the bath every evning after i finsh my work.
Its working very good so far, but how can i keep it stable?
how often should i change the bath?
Amir S.
Amir Shal
student - USA
