finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 8031
Antiquing shiny, polished brass sheet
Hello.
We need to find a simple way to "antique" or make slightly brown brass sheet. We do not want the shiny, polish finish. This finish must remain permanent.
M. Weisbeck
design - Chicago, Illinois, USA
Dear M. Weisbeck,
If you want something semi-permanent, you can try PVD, maybe look up Baldwin Brass. If the brass is going outside, I can assure you that nothing will be permanent. You can oxidize the brass and clear coat it, but will need to refinish it occasionaly. If you don't want a high gloss, get a flat lacquer. Or you can put a dyed lacquer over it and save the step of oxidizing. Either way, you'll need to refinish.
Good luck,
Jake Koch
G. J. Nikolas & Co., Inc.
Bellwood, Illinois
