HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 8021
Non-conductive corrosion coating
We are looking for a protective coating for high speed shafts operating in Cl2,HCL, F2. There is no friction just centrifugal loading. The coating must be non-conducting.
Shawn GibsonRevolve Magnetic Bearings - Calgary, Alberta, Canada
Everbrite Protective Coating is a non conductive clear coating that will protect from oxidation, corrosion and other damaging elements. It may fit your needs.
Teresa Sedmak
Everbrite, Inc. - Reno, NV
