finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 8007
What part does voltage play in electroplating?
I am doing a science project about electroplating and the effects of using different voltages in the process. I have tried to research what exactly voltage does in the process but the only results I've found is that the voltage determines the ions travel.
Can someone expand on this or if it is wrong explain what part voltage plays in electroplating?
Scott Ross
- Los Osos, California
Electricity cannot be seen, so it can be rather abstract. Therefore, for ease of visualization, terms and units that relate to the flow and quantity of electricity are often compared to terms used to describe the flow of water.
The corresponding term to voltage is water pressure.
If you lived in a high-rise apartment alongside a lake and decided to hang a hose out your window to draw up some lake water for your flowers & plants, you would recognize that the water is not going to run up that hose by itself, rather that you'll need a pump, and that how much pressure that pump has to put out will depend on what floor of the high rise you live on.
You need voltage in order to overcome all of the resistances involved in plating, which include the resistance of the copper wires that the electrons flow through, the electrical resistance of the plating solution which the ions flow through, and other resistances. I can answer more deeply what those other resistances are, but that may be beyond the scope of your project.
finishing.com
Brick, New Jersey
I guess I should restate my question, I am testing different voltages 1.5 volts, 3 volts and 20 volts. What relationship does the voltage have to the amount of copper plated onto a zinc plate? Is there a way to have too much voltage to where it would cause a weaker bond? or is there a limit to where there wouldn't be any better results after a certain voltage is reached? If you could explain those resistances in depth that would be great.
Thanks for your help!
Scott Ross
Faraday's Law says you will ideally deposit one gram equivalent weight of metal for every 96,500 ampere-seconds.
When you double the voltage from 1.5 volts to 3 volts you more or less double the current because of Ohm's Law, I = E / R, so you more or less plate twice as fast.
But at 20 volts you will deplete the solution of copper ions in the area of the cathode almost instantly. But the electrons you are making available have to go somewhere--with the result that the electrons will reduce the hydrogen in the water to nascent hydrogen gas instead of depositing copper which isn't there. This formation of copious hydrogen gas, plus atoms of metal being yanked out of solution instantly instead of slowly growing as crystals, is called "burning".
finishing.com
Brick, New Jersey
April 8, 2009
So then what is the difference when you change the voltage (1.5, 3 or 20 volts previously mentioned) but can keep the current constant the same by adding an additional resistance to the circuit?
Philip Bradford
- Raleigh, North Carolina
April 8, 2009
Hi, Philip. You can't do what you are thinking of. If you keep the current that is going through the solution constant, you are also keeping the voltage drop across the solution constant, again because of Ohm's Law.
You can set the voltage at 20 volts and add a big external resistor to eat up a big voltage drop there, but if the current through the solution is constant, the voltage across the solution is constant, and the rest of the voltage drop is across the resistor.
finishing.com
Brick, New Jersey
April 9, 2009
Ted,
Thank you for your answer, although maybe I did not ask my question clearly enough. When I meant extra resistance, I meant between the cathode and anode (with no other resistors in the plating system). It is clear to me that the resistance between the anode and cathode are dependent on the conductivity of the solution, the shape and surface area of the anode and cathode and the distance between them.
Please consider the hypothetical situation. The solution conductivity is constant. The shape and surface area of the anode and cathode are constant. The resistance between them can be changed by changing the distance between them. If the source has a voltage of 1V and the resistance between the anode and the cathode is 1 ohms then the current is 1 amp. If the voltage is increased to 4V and the resistance is changed to 4 ohms by changing the distance between the electrodes the current is still 1 amp. In this situation you should have equal plating rates since the current is the same and thus shouldn't have the effect of depleting the metal ions near the electrode like you mentioned, but your driving force is four times is great. This is the effect of voltage that I am looking for. I know it may not make sense to have your parts meters away from each other in the plating bath just to increase the voltage but I just was hoping to gain insight into the effect.
From the books I have it seems that if you apply toooo much voltage then you get larger over potential which causes your current density to go up exponentially. At what voltage does this start to occur for acid copper plating? In the linear regime what effect does an increase in voltage (assuming a constant current) have? Are there any effects on density, morphology, macro and micro throwing power, etc.?
Thanks for your help.
Philip Bradford
April 10, 2009
Hi, Philip. I think you're still not quite accepting all of the implications of Ohm's Law :-)
If you put the anode and cathode further apart to keep the current constant as you increase the voltage, you're still just looking at a voltage drop across an "external resistor", although in this case the "external resistor" is the extra plating solution between the anode and cathode rather than an actual external resistor. And in fact, practical experience shows the qualities of the electroplated metal to be the same whether the anode to cathode distance is a couple of inches or several feet.
There is a diffusion reaction in the boundary layer around the cathode as the plating proceeds. If you plate very slowly you tend to get large crystals because there is copper available when the electron touches it. If you plate faster, but still in conventional plating range, you get more adatoms and smaller crystals. If you try to plate still faster, you get burning. Good solution agitation keeps plenty of copper available just outside of the boundary layer, and extreme agitation (directing a high pressure stream of fluid at the cathode) reduces the thickness of the diffusion layer and allows faster plating. Pulse plating produces some changes in plated layer properties, but some people feel that the only real mechanism behind that is that the pulses cause agitation in the boundary layer -- but maybe not; maybe if you had pulses of microsecond duration instead of millisecond duration you could engineer the plating at a nano level.
finishing.com
Brick, New Jersey
April 13, 2009
Ted,
What you have said makes sense. Now I have more followup questions for you!
Is there some minimum voltage/current level that you need to be able to reduce the metal ions to make the pure metal at the cathode? I know the standard value for the reaction is positive, +0.34 V, so I am assuming that there is no minimum voltage required but electrochemistry is not my strongest subject so I won't feel bad if you tell me I am wrong. The reason I ask is that I am trying to plate copper at an extremely low rate to be able to fill voids on the order or tens and hundreds of nanometers wide and my thickness only needs to be on the order of hundreds of nanometers so deposition rate is not a concern. I will use ultrasonication to agitate the solution. I know that using pulsed plating techniques researchers have avoided bottlenecking to fill deep nano-voids but I am hoping to get around buying a $5k pulsing power supply by slowing the plating to the slowest possible rate and providing good agitation.
Do you have any more tips or starting points for the bath copper and sulfuric acid concentrations that might give me the best results for plating in small voids, considering the fact that I want to plate very slowly? Thanks!
Philip
Philip Bradford
April 14, 2009
I believe you have the half cell potential for Copper correct at +0.34 V. If you were plating copper onto silver, which has a half cell potential of +0.80 V, you would need a minimum of 0.46 V to get it to deposit. If you were plating onto iron, which has a half cell potential of -0.41, the copper will spontaneously immersion deposit onto the iron while generating 0.75 V.
These potentials are for standard conditions, and I believe that the Nernst equation can get you more realistic numbers for your actual situation.
Sorry, but I have no experience in the area that you are exploring (trying to fill nano voids). But "brighteners" have long been used in the plating industry to try to get more uniform plating. They work by (at least partially) blocking a surface so that the electricity is steered towards causing the metal to deposit elsewhere, resulting in smaller grain, brighter deposits, and more even distribution.
The following is from an engineer, not an electrochemist, and it is a simplification -- but here's the way I understand it: In order to copper plate thru-holes in thick multilayer circuit boards, where the current is very low in the hole but very high on the surface, they have developed developed special brighteners. These brighteners have molecules so large that they can't get into the hole to block deposition there, but cover everything else. The result is copper is deposited deeply into the thru-hole. Please talk to one of the major suppliers about their acid copper process for thru-hole plating. In may be what you need.
Also, please see our library article "A Review Of Copper Plating High Aspect Ratio Plated Through Hole Papers" contributed by Paul Stransky.
finishing.com
Brick, New Jersey
December 2, 2011
Hi, if let's say I am depositing my cathode (1 cm2) and my anode is (1 cm2) as well, with a distance between them set to be 1cm apart from each other, what does the voltage supply encourage to perform? As my current vs. time graph did not increase after capacitive charging effect.
Bryan Pang
- Malaysia
December 2, 2011
Hi, Bryan. I'm not quite following your question. And in view of the previous rather long discussion, I am therefore not sure if you followed it and are asking a follow-up question, or you blew it off and are starting over :-)
Regardless, think of it this way. Each atom of a metal has electrons. If you use a battery or power supply to pull electrons away from a metal anode, through the wiring, and over to the cathode, what will happen in electroplating is those metal atoms which are now short on electrons will dissolve into the solution as positively charged ions, and migrate through the solution over to the cathode -- at which point they will reacquire those electrons and the metal will deposit on the cathode. In brief, if you move the electrons, the positively charged ions will follow.
But this is not only qualitative, it is quantitative. In an acid copper plating solution, where copper ionizes to the +2 state, if you move 2 electrons from the anode to the cathode, one copper ion will follow. Faraday's Law is the mathematical expression of this.
This situation will persist over a fairly broad voltage range, i.e., the higher the voltage, the more electrons will flow, and the more metal will plate out. However, if the applied voltage is too low (in the neighborhood of less than 1-1/2 volts depending on the position of the metals in the EMF series) then no current will flow. That is simply because those two metals in solution are comprising a battery themselves, which you must first overcome. And if the voltage is too high, the electrons start piling up at the cathode and can't "wait" for the metal ions to get there, and will instead start pulling hydrogen out of the water, "depositing" it as hydrogen gas on the cathode.
finishing.com
Brick, New Jersey
