letter 8000
Bright Dip for Beryllium
Greetings,
We are looking for a way to bright dip beryllium. We have found a
number of solutions which will etch the surface resulting in a satin
or matte finish. What we need is just the opposite- a leveling effect
with, hopefully, a minimum of material removal. Any ideas?
Thanks in advance for your replies.
Keith Wicklund, CEF-SE
avionics - Minneapolis, Minnesota
Keith.
I have information for you I believe you can use. If you have
access to a book named "Gold plating
technology" by Frank H Reid And William Goldie, by
Electrochemical publications, page 131 will detail for you how to
pretreat beryllium. It gives a chemical polishing make up along with
metal removal rate. I have heard this stuff is poisonous to deal with
and you will want to be extremely careful handling beryllium.
Todd Huehn
Spec
Plating - Minneapolis, MN
Dear Reader, please --
- Post a
question on a different
subject.
- Answer this question (in non-commercial fashion).
