finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 7610
Need some advice on Chrome Stripping
Question about stripping Chrome Plating I have 3 old (1940's) barber chairs that I would like to strip and refinish. They are a combination of Chrome plated cast iron, aluminum, and stainless steel. I don't want to re-chrome the chromed parts but I do want to strip them of the old bubbling and flaking chrome. I would like to powdercoat and/or use automotive paint on the parts once stripped.
The problem I have is the local shops (Sacramento, Calif) are telling me that you can't just strip the chrome because the stripping process/chemicals can't be neutralized. Therefore you must re-chrome them. I'm no chemist but this seems odd to me because one can usually neutralize a chemical reaction with another chemical. Right? What is the real answer. Can I have the parts stripped and neutralized or what? If yes, then what is the process?
I attempted to sandblast a part with no luck . If this can be done I would then be able to fill and prep the parts before coating with powdercoat or automotive paints.
Thanks in advance for your feedback. I would really like to restore these because they are from a family members shop.
Doug Gale
-Sacramento, California
Dear Doug,
The "bubbling and flaking chrome" on your barber chairs is probably nickel rather than chrome. Chrome is usually a very thin coating that protects the nickel and prevents discoloration. Stripping process/chemicals can't be neutralized? You're right, that's ridiculous.
If you would like, I will refer you to companies in your area that distribute our nickel strippers and may be able to give you the names of plating shops that can help you. Note: Since these chairs were manufactured in the 40's they may not have a nickel/chrome finish. During WWII many manufacturers suspended the use of chrome for commercial products, reserving their chrome supplies for the war effort. If the chair parts do have the nickel/chrome combination, the chrome is easily removed by submersion in an electrocleaning tank and applying reverse current for a few minutes. The nickel can then be removed by immersing the parts in the nickel stripper. Hope this helps.
Gayle Coffey
Metalx, Inc.
Lenoir, North Carolina
Ed. note: Other threads about barber chairs include letters 24359, 26677, 40093.
Barber Chairs on ebay
