Letter 7359
How to paint plastic
If anyone can tell me how to paint onto plastic, please reply
a.s.a.p. Thank you.
Jenni F
[last name deleted for privacy]
- Bury, Manchester
What kind of plastic do you have? I am trying to find a way to
paint plastic molded chairs and I have gotten a variety of responses
form local artists that might help you. Some hobby shops carry paint
for painting plastic models (airplanes, cars, etc.), but it depends
on the type of plastic that you are trying to paint.
If you could give more details, I might be able to help.
Myra S
- Loveland, Ohio U.S.A.
Jenni, as Myra said, you really should know WHICH plastic you are
talking about.
There are many 'plastics' just as there are many 'metals'. Some
don't take kindly to painting, ie. Teflon but also Polypropylene and
Polyethylene (PE), and PE has a waxy feel, anyhow (super for fridge
ice cube holders etc. etc) So what have you got? PP or PE will both
slowly burn and will both drip. PE will always smell of candle wax.
Cut off a sliver and put a match to it to try this out. If you have
PVC, Acrylic (ie. plexiglass) or ABS or variations of these, these
thermoplastics can be cemented so then consider a paint that will
'attack' the plastic, ie. a lacquer and not a latex. The test for
these is simple. PVC doesn't burn, it just gets soft and stinks.
Acrylics burn slowly and smell sweet. ABS burns quite well and gives
off black fumes and it pongs.
Myra's deck chairs are made, I'm pretty sure, of an impact
modified PVC although perhaps manufacturers might use a UV stabilized
ABS. ABS is weaker than PVC (not as rigid) but is much better on
impact. Anyhow, dammit, when the chairs were bought, the packing
would SURELY show what material they were made from. Fortunately no
one is making items from a super plastic called Cellulose Nitrate
(hence the film name of celluloid) as that REALLY burns. Dangerous.
But super for ping pong balls which, although modified with Naptha,
cannot be excelled by any other known plastic.
Lastly, please preclean before painting. To get a better job of
adhesion, sand down very slightly, too.
Cheers!
Freeman Newton
- White Rock, B.C. Canada
A 2K urethane works on most plastics with the exception
of polyolefins (polypropylene or polyethylene) these require
a special epoxy that needs a 250 ƒF bake to activate after
application.
Ron Zeeman
continuous coating - Brampton, ON, CAN
Jenny,
"fusion" from Krylon paint for plastic comes in a
can and I bought some for my plastic chairs.
Catherine V [last name deleted for privacy]
- Eureka, Ca, USA
Hi,
I was just wondering if anybody out there knew how to paint
plastic, because I'm redoing an old snowmobile and I would like to
know how to go about finishing the hood of it. Any help would be
rather helpful.
Thank u!
Wayne M
hobbyist - Heatherton, Nova Scotia, Canada
I stunt motorcycles. Meaning I break plastic on a daily
basis... first off, like Mr Freeman said, know what you are
painting. and hope it is ABS... abs is most common for
sportbikes/snowmobiles. Polywhatever is used on
dirtbikes/atvs... obviously, this is not written in stone. I
wouldn't recommend painting a poly part, just replace it; it
is a lot cheaper than abs. If you're not sure, abs is quite
rigid, poly is malleable to the extent that you could almost
bend it in half without breaking it, depending on thickness
of course. What's going to happen if you paint something
thats hella flimsy? Kurt lammon writes
the
best book I've seen about plastic repair/painting... if
you want to save some cash and experiment a little... here's
a tutorial http://www.sportrider.com/tech/146_0204_body/
this is one of the cheapest places to get plastic welding
supplies, short of finding the crap on ebay ---> >
http://www.aircraftspruce.com/catalog/cmpages/plasticrepair.php
you'll have better luck if your plastic doesn't have pigment
in it. sand it smooth, soap and water, weld your cracks,
krylon primer,
Krylon Fusion , and then throw it on the
pavement at 40 mph again... repeat...
David Nelson
- Beale AFB, California, USA
I was wondering how to paint plastic and any help at all
on this subject would be greatly appreciated!!
Thank you!
Joseph Francis
Knight
- Leyland, Lancashire, England
...Funny...I was just tackling that very job and ran into
the same problem. I called a friend of mine and he said you
have to sand any plastic surface before you attempt to paint
it. Then apply a plastic primer, then your paint.
(specifically made for plastic).
Good luck. I am taking his advice, and will let you know the
results.
Ruth Coleman
- Aliquippa, PA
I am planning on painting a stripe on a Sears cartop carrier. I
have been told that there is a hardener to use that is for plastic
car bumpers. Anyone know anything about this?
Tony Hallum
- Hobbs, NM
May 20, 2006
How should I paint motorcycle plastics? Sand, Primer, and paint??
Patrick Hill
Nascar Images - Mesa, AZ
June 4, 2006
I want to paint these plastic cubes that I use to teach in a math
class. The material is somewhat shiny and smooth. I've tried acrylic
and it peeled off. Any suggestions?
Kristin Wiese
Teaching - Palatine, IL, USA
July 17, 2006
Krylon Fusion Plastic Paint claims there's no priming, chipping,
it adheres and dries in an hour. Maybe this will work....
Robyn Peterson
- Nashville, TN
April 13, 2007
I want to paint and decorate a plastic see thru sheet, like a
vinyl shower curtain! Does anyone know what I can use so that the
paint doesn't crack or chip?
Eliza Lee
hobbyist - Vancouver, BC, Canada
June 5, 2007
I just bought a 98 ez-go golf cart. It has some scratches on it
and one actually dug a little into the plastic body. I want to
repaint it but not sure of how to fill in the scratch that dug in the
body or how I should go about painting it and what type of paint to
use.
Mike Winegar
Consumer - Indianapolis, IN, USA
July 3, 2007
Hi,
I would like to attempt painting small objects on a plastic film. I
would need to use a variety of vibrant colors. Can anyone out there
help with some answers? Like maybe an artist who paints on clear
plastic film...Is there a particular brand of paint that I need to
use, hopefully one that carries a wide variety of colors?
Rachel Harris
hobbyist - New York, NY, USA
July 10, 2007
I am having a problem getting a durable finish on ABS body panels
off a motorcycle. I am thinking of trying the Krylon Fusion and if it
is durable topcoating with a clearcoat for better protection against
chemicals that might come into contact with the finish. I see
suggestions to primer and then use Krylon Fusion. Isn't the whole
idea behind the Krylon Fusion that it bonds with the plastic better
than conventional paints (and presumably primers)? If you primer then
the Fusion paint technically never touches the plastic so what would
the point be? Couldn't you use just about any flexible paint if you
bothered to use a good primer that bonded well to the plastic? In a
nutshell - Why would you use Fusion after primering?
Stanley Jablonski
hobbyist - San Antonia, TX , USA
July 11, 2007
For those of you out there trying to paint shower curtains, vinyl
tablecloths and the like, Plaid has a paint line for plastic. It has
like 37 different colors. I can find a small assortment at my local
craft store.....but you can buy the whole line primer sealer and all
at their web site. I recently made a custom picnic set table cloth,
dishes and all. It has with stood even the dishwasher! Hope this
helps.
LISA FONNESBECK
- Las Vegas, NV
December 14, 2007
I have decided that a large water tank in small garden is an
essential but it is sticks out too much, thought i would paint a
scene on it so it blends in more with the garden setting, it is
plastic corrugated and cream colour any ideas what sort of paint i
would need,we have reasonably extreme temps here down to minus 7c and
high as 40c.Appreciate any advice thanks
Linda Mawbey
hobbyist - Goulburn N.S.W. Australia
December 27, 2007
hello there...
I was wondering if anyone could help me as I want to paint something
onto a plastic bass drum skin and I have no idea what kind of paint
won't ruin it. If not paint i thought maybe cellophane with adhesive
glue.... thank you x
Melanie Heslop
hobbyist - London
August 11, 2008
I see the last post to this issue was in December last
year, hope someone is still around with possible
solutions!
[Ed. note: Per google, 1025 people
visited this specific page in the last month, spending an
average of 5 min. 40 sec. on it -- they're here if you can
motivate them to help you] :-)
I am trying to paint marine life rings (the kind you toss to
a drowning person). They are white, slightly textured and
what I thought were a plastic of some kind. I am hoping to
use them as address markers along the highway. I considered
using Kilz [link is to product info at Amazon] or
BIN Primer [link is to product info at Amazon] as I've
had good luck with that on many unusual surfaces, but this
was about the time the spray plastic primers came on the
market. I could swear Krylon was the first and had a plain
white primer. Unfortunately I used the whole can and tossed
it, since I painted four rings. I have no way of knowing the
brand!
Well, the paint crazed (alligatored) as soon as it hit the
primer, but not in all places, just spotty. Now, after a
year later it *still* isn't dry! It's tacky and sticks to
anything it sets on for more than just a few minutes. The
paint is peeling down to the original surface and can
actually be peeled off in strips---like it never stuck in
the first place and just formed a flexible film.
I contacted Krylon and they claim they never made a primer,
only their Fusion (colored) product. I'm almost certain it
was Krylon! The only company I can find that makes a "primer
only" now is Rustoleum! I'm pretty certain it couldn't have
been that company or I wouldn't have been concerned about
the compatibility issue.
So, I'm stuck! Help! I've already detail painted the one
painted ring (Dumb, I know! I thought the "tackiness" was
going to eventually dry, and the top-coat detailing "is"
dry) which means I've lost the work that went into it, but I
have three more to do.
Does anyone else remember the "Plastic Primer" when it first
hit the market a year or so ago? I remember it's claim was
it could be used to prime any plastic, then you could
topcoat with any paint! Was there another company making it?
Any idea what might have gone wrong and any suggestions for
how to proceed now? Like I said, I still have 3 rings
already primed---I'm afraid to topcoat them, I *hate*
stripping paint, and I'm not even sure I could on
plastic!
Really, REALLY appreciate some input!!
Linda L
- Hoodsport, WA
August 13, 2008
Hi, Linda. It could have also been
Bulldog Tie Coat [link is to product info at Amazon].
Obviously it's hard to guess what you might have used, and
anyone's recollection of the market situation is going to be
colored.
But I think your recollection has perhaps exaggerated
their claim to work on any and every possible plastic. But
at this point you have paint that won't dry, and
unfortunately that's not really unusual nor readily
curable.I think you should strip and repaint one ring with
the primers you have more confidence in, and wait until it
dries before you make further decisions. Good luck.
finishing.com
Brick, New Jersey
August 13, 2008
Thanks Ted!
I checked out the Bulldog Tie Coat and I seriously doubt that was
what I used! It looks like that is probably an automotive primer and
costs way more than I would have spent. I would have bought it at
somewhere like Lowe's, Home Depot or WalMart.
After receiving the response from Krylon, I Googled "Krylon Plastic
Primer" and found several references to it. I suspect it was on the
market for a short time (gee, I wonder why???) and they replaced it
with their Fusion line.
I have replied to their response and asked them to "look deeper" into
their discontinued stock. Not sure they will, I usually find answers
like the one they gave me are just boilerplate---but *sometimes* they
will follow-up! I told them I need to know what the base is and what
it is compatible with.
In the meantime, I guess all I can do is strip this one off and start
over. For the other 3 I will try a small area with a different paint
to see what happens. I didn't really want this to be an expensive
project, since the first life ring is for an address marker on a busy
highway and stands a good chance of being stolen! I only paid $4
apiece for them several years ago, but I'd like to use the remaining
ones on my dock. I had hoped the Rustoleum paint would be good to use
as I have had good luck with it in the past.
Funny, I almost used a cheap, $1.99 rattle can I had here! Wonder if
it might have worked better ;-)!
I'll let you know if I hear back from Krylon---and thanks again for
getting back to me!
Linda
Linda L
- Hoodsport, Washington
Dear Reader, please --
- Answer this question or ask a
followup (in non-commercial
fashion).
- View
the most current finishing questions and RFQs
- Post a new
question
- This is a monitored
forum. If you spot broken links or obsolete info, please
advise!
