letter 7096
Hot Dip Versus Electroplating Versus
Phosphating
i HAVE A QUERY ON HOT DIP GALVANISING VERSUS ELECTROPLATED VALVES.
WHICH OF THE PROCESSES IS BETTER. WHAT IS THE COATING THICKNESS
ACHIEVED IN HOT DIP AS WELL AS ELECTROPLATED VALVES.
ALSO CAN CAST STEEL AND CAST IRON VALVES BE GALVANISED BY BOTH
PROCESSES.
PLEASE TELL ME IF PHOSPHATING IS A BETTER SOLUTION FOR GALVANISING
REGARDS
AMEET YADAV
KVAERNER POWERGAS INDIA LTD - pune, maharashtra, india
Hot dip galvanizing and electroplating both deposit essentially
pure zinc metal as a sacrificial coating. There is an old truism:
"Zinc is Zinc". So it doesn't matter which way the zinc was put on,
only the thickness matters. Practically, though, zinc plating is more
economical for thin coatings up to say .0006" and galvanizing is more
economical for heavier coatings.
Cast steel and cast iron can be electroplated; I'm not sure of
practical limitations on galvanizing of these metals.
Phosphatizing offers almost no corrosion resistance iteself, but
it vastly improves the corrosion resistance of painted finishes.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Post a
question on a different subject.
- Answer this question (in non-commercial
fashion).
