Letter 7074
Power supply for home use
I currently have a anodizing set up at home,which is working very well on small parts.I am getting many requests for anodizing larger Items. My current power supply is 2 12-volt batteries connected in series,hooked up to a 30 amp battery charger [link is to product info at Amazon],running through 5 1-ohm variable resistors.My problem is, as I pump up the amps my voltage drops right off. Does anyone know where I can get a power supply that will run off 240 volts single phase and give me 12-18 volts DC and be capable of pumping out at least 50 amps
Thank you for any information
Kind Regards
Steve Power
- Nelson New Zealand
This is what people would call a single-phase bench rectifier. Click on the "Products & Services / Chemicals & Equipment" button below, type in "rectifier", and you'll get a good list of suppliers with full contact information.
If price is an important criterion, you may find that a used high-quality industrial bench rectifier is a better investment than a new "toy rectifier".
finishing.com
Brick, New Jersey
Steve,
There are several bech top units that will work for you used in Brush Plating applications meeting the requirements of government and corporate agencies.
David Crocker
Brooktronics Eng. Corp. - Valencia, CA. USA
Dear Reader, please --
Post a question on a different subject.
Answer this question (in non-commercial fashion).
List of Directories
