Letter 7057
Need product to remove copper oxidation
I'm a chemical engineering and I work with copper in my job. I need a copper cleaner, a product that removes the superficial oxidation in copper. I have used nitric acid, but the oxidation remain. thanks
Marcelo Tirelli
- Lorena, Sao Paulo, Brazil
If you can handle HNO3 you can probably handle this solution:
120 g/L sodium persulfate
30 mL/L concentrated sulfuric acid
This is actually a copper etch; there will be metal removal and the resultant surface will be active. A benzotriazole or citric acid solution can prevent further tarnishing.
James Totter, CEF
- Tallahassee, Florida
Dear Reader, please --
Post a question on a different subject.
Answer this question (in non-commercial fashion).
List of Directories
