Letter 7053
Waterborn help needed
In a bind need to find a good waterborn sealer and lacquer that has the same dry time as a pre-cat lacquer.This may sound trivial to you but it is of the most productive importance to me and my finish dept.The Pres. of the company wants to put in aa oven that would take up 1/4 of my production space.
Russell ST.Clair
- sunvalley,Nv. USA
Russell
You don't say what you are coating. There are waterborne acrylic laquers and sealers on the market. Usually take approx 20 mins dry to touch. With a little air flow less time. You do not indicate if you have blocking requirements, UV and the like. There are also fast cure 2k urethanes or even UV cure. UV cure oven takes up very little space. Hope this helps
Gordon Vidt
Industrial Coatings Enterprises - Heath Ohio
Dear Reader, please --
Post a question on a different subject.
Answer this question (in non-commercial fashion).
List of Directories
