HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 7026
EN on Aluminum questions
Has anyone used EN in conjunction with Aluminum? What would be the major difficulties? I have a situation where it is being used with some real thermal expansion problems..Can anyone shed some light on this for me?
John Bettiga- Corpus Christi, Texas USA
The process involves cleaning, etching, de-smutting, double zincate, high PH EN and then regular EN. If you do all these you will not have any problems. It is a well known process.
I AGREE WITH THE OPINION OF SARA, BUT I THINK THAT THERE IS ONE MORE THING TO ADD. ABOVE 300 DEG CENT. ELECTROLESS WILL BEGIN TO CRYSTALIZE AND HARDEN SO THE PART DESIGN AND THE PLATE THICKNESS HAS TO BE REVIEWED CAREFULLY TO AVOID DEEP LARGE CRACKS OR SPALLS.
