finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 7017
Zinc coating corrosion prevention
Hi,
I'm a final year varsity student and now I'm attached with my final year project. My project is on corrosion field. I'm doing zinc coating as a cathodic protection coating, in which the zinc will act as an sacrificial element to protect the inner metal. The objective of my project is to determine the best process between electroplating and hot dip galvanizing, both with zinc. I would wonder what kind of industry can I relate to with my project, so that it can ease my research. Any opinion or suggestion is very much appreciated.
Eric Raymond
- Johor, Malaysia
Hi,
Your subject has a lot of application on ships which are coated with zinc in order to avoid corrosion
WJOOD .T.S
- IRAQ
Try automotive, HVAC or any industry that uses galvanized steel for atmospheric corrosion applications.
Your best best is to contact AK steel in Ohio.
Kam Dianatkhah
- Dallas, Texas
Answer the best industry to look into zinc coating is the gas turbine industry.
Eytan
- TLV, Israel
