Letter 7012
Probem with Tarnishing of Silver plated
buttons
Hi
I've had some difficulties with silver plated buttons being
attached to garments tarnishing within hours of the buttons being
attached to the garments.
The buttons do not tarnish before they are sewn onto garments, and
in testing I've done they only tarnish when tested in an environment
that includes the wool fabric they are supposed to be sewn onto.
I need to find out what is causing the problem so that I can
eliminate it. Is it likely to be poor plating of the various layers
that go on to the alloy button before the silver is applied?
As you can tell, I'm no plating expert !
Andy Nathan
- United Kingdom
It sounds to me like the wool cloth is giving off a chemical vapor
that is attacking the silver. I don't know much about textiles, so I
have no idea what the material may be. Sulfur compounds are the most
common chemicals that tarnish silver. Does the fabric smell unusual?
Laboratory analysis of the tarnished silver would give a clue.
Some analysis of the fabric may also be possible. You could try
washing a sample of the fabric, then expose the buttons to samples of
the original fabric and washed fabric. If the washed fabric does not
cause a tarnish and the unwashed fabric does, you will know that the
fabric is the culprit.
Larry Hanke
materials testing laboratory
Minneapolis, Minnesota
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
