Letter 6084 Stainless Steel Preparation beforepainting. We are going to be powdercoating a stainless steel part which willbe used on boats and subjected to saltwater and to fuel. We are goingto use a zinc rich epoxy primer and a TGIC polyester topcoat, but Iam unsure as to the best approach on preparing the stainless steel.Any help would be appreciated. Melanie Rogers . My Dear Melanie; You want to do what to the stainless steel? It sounds almost sacrilegious to be powder coating stainless. If it's corrosion protection you are seeking I would recommend you consider electropolishing. You will suffer no problems with delamination and it will provide you with both an aesthetic and durable finish.
+ Sir: We have had excellent results on S.S. for underocean applications by blasting to a N.A.C.E. #1 -white metal blast and applying a single heavy coat (3 mils) of your top coat. If U.V. stability isn't essential,definently use an epoxy pc. Robert Modisette
++ Generally stainless steel only needs to be cleaned before painting. Specific treatments are not required but can be used. Ron Zeeman
Dear Reader: please choose what you want to do.
Save
