HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 6082
Difference Between Chrome and Nickel Plating
Can anyone direct me to a source that explains, in a fairly SIMPLE way, the difference between chrome- and nickel-plating? i.e. when would I choose one over the other?
I am just curious about it; I do not intend to go out and buy equipment for doing it. I work for a fittings distributor and noticed that some ball valves are chrome-plated while others are nickel plated.
Thanks for all your help.
Tiziano Bianchi- McKinney, Texas
Chromium and nickel are two different elements, so they have somewhat different properties.
Conventional electrolytic nickel plating is decorative, functional, and corrosion resistant but it tarnishes and it is not as hard as chromium.
Electroless nickel plating (actually autocatalytic nickel plating) is a glassy nickel-phosphorous coating that is very corrosion resistant and quite hard, and often used on rough-service applications like down-hole applications.
Chrome plating may be either a thick layer of chrome (generally known as hard chrome) that offers exceptional hardness,wear-resistance, and oil-holding capability, but limited corrosion resistance; or it may be nickel-chrome (nickel plating followed by a flash of chrome for tarnish resistance and extra corrosion resistance, as is employed on truck bumpers and automotive brightwork).
I have an antique Aladdin kerosene lamp it's chrome plate is entirely polished leave only whole brass body. I've seen that re-chrome is easy to peel off within few years so I decide to try nickel plating, I like nickel's antique-like yellow shade (compared to chromium). I think local workshop can do only electroplating so I'd like to ask that is it good idea to plate brass lamp with nickel or any better suggestions.
Mr. Jirapan PankongchuenThai Military Bank(pcl) - Nonthaburi, Thailand
No, that is not correct, sir. It is very unlikely that the lamp was chromium plated; it was almost surely nickel-chromium plated; that is, it was nickel plated then chrome plated, with the chrome being only a few millionths of an inch thick. So if something peeled, it was the nickel plating.
But if the job is done right the nickel will not peel. You are correct that nickel plating which is not later chrome plated has a slight yellowish tinge which grows more pronounced with time as the nickel tarnishes.
Thank you so much for your help, Ted.
Jirapan Pankongchuen- Nonthaburi, Thailand
January 5, 2009
Dear editor, could you throw a few details on this. I have seen an shiny chrome / nickel chrome plated dog collar go rusty within a few a minutes of entering sea water. was it defective ?
Srinivas Somalahobby - Hyderabad, AP, India
January , 2009
Hi, Srinivas. Anything can be done well or poorly, but chrome plating is a special case that can be done really really well or really really bad (see our Chrome Plating FAQs). When done poorly it contributes nothing to corrosion resistance and actually accelerates corrosion. Defective is not the correct word because it may well have met the plating specification they wrote for it. Crappy would probably be a good word :-)
February 11, 2010
Hi,
I'm looking for a chrome or nickel plated stair rail. what would you suggest for this application. Also are are they both the same colour, the reason I'm asking is because all our door handles are brushed chrome.
Many thanks
- England
March 2010
Hi, Trev. Nickel and Nickel-Chrome plating are rather similar in appearance, with the nickel plating being slightly yellowish due to its tarnish, and the chrome being slightly bluish. Either on a railing would probably be "close enough" to match a chrome door handle.
January 22, 2011
I have a nickel allergy and was wondering about chrome items, not necessarily jewelry. Anything touching my skin long enough will evoke a reaction. Are there chrome items that are not also plated with nickel? Is there such a thing as solid chrome?
Kristen Clarke- Virginia Beach, Virginia, USA
January 24, 2011
Hi, Kristen.
You won't find solid chrome jewelry. What you may find though is nickel-free rhodium plated jewelry. I believe that all jewelry sold in the European Union is supposed to be free of nickel.
