finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 6075
Hours of salt spray for electrogalvanized auto body
Dear sir/madam
At the moment I am trying to find out what is the recommended hours for salt spray test for auto body zinc coated (electrogalvanized) panel sheet to SAE and ASTM standard. thank you for answering.
regards
Nariman
Nariman Mirzade zare
- Tehran, Iran
Specific pass/fail requirements for corrosion are nearly always specified by OEM specifications and not by SAE or ASTM specs. You will have better luck looking for a specific automotive company's spec for auto bodies. Corrosion specifications differ from one component to another, which is why there is usually not a generic spec.
Tim Neveau
Rochester Hills, Michigan
