Letter 6072
Need for phosphating before fluidized bedthermoplastics?
Does anyone know if it is necessary to use an iron or zincphosphate when using thermoplastics in a fluid bed process? I thoughtthat phosphates were used primarily in electrostatic powder sprayoperations.
Chris
Chris Ballew
- Newport, TN. USA
If you are preheating the metal prior to coating it will beeffectively destroyed by the heat. You can use iron phosphate if itis a convenient method of cleaning the parts. Temperatures below 250deg C are just about allowable to zinc phos but there will be someloss of performance. Post cure certainly benefits from properpretreat giving enhanced performance.
Roger Bridger
Walterisation (UK) Ltd - Croydon, UK
If you are applying an organic coating such as plastisol over steel, then yes, you may use iron phosphate as a pretreatment to facilitate adhesion. I have direct experience with just such an application with a fluidized bed.
Ron Woods
Benchmark Products Inc. - Indianapolis, IN
Dear Reader: please choose what you want to do.
I want to post a question or inquiry of my own.
I want to answer this question publicly (in non-commercial fashion).
I am a supporting advertiser and want to reach the inquirer privately.
