letter 6061
Safety / environmental issues in
aluminium degreasing
I have been asked to assist in the setting up of a aluminium
degreasing plant for high volumes of medium size components. I need
information on the practical aspects like plant and chemicals and all
the health & safety / environmental issues in particular. .. Once
again major request for help.
Ziya Ahmad
Ash & Lacy Perforators - West Midlands, England
I am not familiar with the aspects of aluminum degreasing, but one
of your first steps should be to identify what kind of chemicals you
will be working with and get copies of their MSDS sheets. (Material
Safety Data Sheet) This sheet will tell you all of the information
you will need to know about health, saefty, and similar issues. If
you do not have a chemical vendor yet, you can get free copies of
MSDS sheets from the University of Vermont at:
http://hazard.com/msds/
Tim Neveau
- Auburn Hills, MI
We put in a trichloroethylene vapour degreaser 3 years ago. One of
the major considrations was getting local authority consent. The
solvent emmissions can be very well controlled (at a cost)so the
safety issues are less problematical. If your system gets planning
consent you will probably be well inside safety limits. We required
as support plant: High pressure hot water and chilled water. The unit
had oil superheat and supercooler as standard. It was also not the
easiest purchase we have ever made the unit was made in California
and assembled on site.
If you can use one of the water based solution degreasers then my
advice would be to use one of those. Environmental issues are putting
tighter controls on solvents every year. On solution degreasers, lip
extraction on the tank is at least advisable and spray rinse on exit
as well as dip rinse is worth considering for the ease of tank makeup
and solution control particularly on heated solutions. If as your
company name suggests you are degreasing perforated aluminium sheets
hot air drying is a must after rinsing.
Ciaron Murphy
Nordam Europe - Great Britain
Hi Ziya,
I liked what Ciaron said about water based solvents & air
drying.
Personally I know zilch about trichlor except that it needs
'chilling' to condense the vapours. There used to be (?) a UK solvent
called THORPIC which I guess is nearly the same.
One problem you might well have with hot air drying is the cost,
obviously, of the heat.
Depending upon the part sizes you want to 'clean' you might like
to consider what G.M and Blackstone (both mfgs of car radiators)
amongst others, did.
They used an ambient air WIPE to blast off the droplets (alkaline,
I believe) at high velocity. Works very well except for droplet
carry-over. The Swedish Company of Oelstrom made the original
Blackstone (sic. Chrysler) spray box but this used both a push fan
and an exhaust fan with an eliminator (mist type eliminator, I mean)
in between.
An improvement was made using only one fan and a far better mist
eliminator but the design was vetoed originally by the U.S. parent
Company ... who later on COPIED, would you believe, this successful
approach! Made my day!
In the UK there used to be (?) a Company called Plastic
Constructions in Birmingham whose eliminators, blade type (blades
were made by Euroform of Aachen) were of excellent quality.
Maybe this might be of some help. I dunno. Here's hoping!
Cheers !
Freeman Newton
A.V.I.D. Acid ventilation industrial design - White Rock, B.C.
Canada
The cleaning of the Al. surface depends largely on the type of
lubricant used in the process when the parts are made. We do Al
drawing the surface of the finished product has to be super clean in
order to meet the end results after the next process operations, what
has worked for us so far is the use of Ultrasonic cleaning bath, the
chemical used for the removal of the lubricants is a hydroxide base,
the process is limited in speeds and requires some maintenance, the
used solvents can be neutralized for disposal.
Best regards,
Moe Jaber
- Milford, NH, USA
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
