HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 6030
How to get Metallic or Pearl finish on lamp
Hi, I refinish antiques for fun, having some trouble with latest project. Need advice re: how to resurface an old desk lamp = decostyle (steel base, goose neck). I stripped the gray paint and now want to repaint it. The paint needs to withstand the heat of the light bulb. I'd like to paint it a metallic or pearl. I thought of car paint, that's the type look I'm after, would have to take it to someone, could be expensive proposition. I live in NYC. Does anyone have any advice? Thanks,
Kerry M [last name deleted for privacy by Editor]- ny,ny
You can get fancy spray paints out of a little shaker can these days, Kerry. With a little patience and a number of thin spray coats, it's certainly something the average person can do. And while light bulbs get hot, I don't think you would need a special high temperature manifold paint or ceramic paint for a light bulb housing. Maybe Krylon Make It Iridescent
