finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 53623
Need Plating on Engineering Plastics LCP COC
Plating on Ultem and LCP pointer
November 15, 2009
I am designing a part that requires a Ni (or Cr) plating on a plastic substrate. I am currently considering either a COC or LCP plastic (will consider others but have stringent requirements) The application requires a reflective surface 1um is more than enough, also need the vapor barrier so thicker is desirable. The parts need to stand up to standard rel testing 85%RH 85C thermal cycling -40C to 85C. These are very small parts (about 10 mm x 6 mm x 4 mm) right now I need to make a couple of hundreds, we hope to get up to thousands per month when we go to production with the part.
I'm looking for a job shop experienced with these or simiar materials.
Michael Martin
OEM Laser Diode Produces - Madison, WI, USA
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
