Caplugs
  53480
Surface finish is roughened by phosphating [India]
October 29, 2009
We are facing problem of disturbing surface finish after maganese or Zinc phosphating. We required the same surface machined finish after phosphating. What will be the process for the same. Is there any alternative process to Phosphating. We are doing it for the rust prevention of our ball valve after testing.
AniL JAdhav
manufacturing Manager in valve industry - Pune Maharashtra India
contact button
October , 2009
Hi, Anil. Phosphatizing is supposed to roughen the surface, to provide tooth for painting or to hold oil for improved dry running. You can't ask it to read as a polished machine surface.
If you need a polished surface, you could try electroless nickel plating . . . but are you sure that the phosphated surface is the problem rather than your spec being the problem?  :-)
finishing.com
Brick, New Jersey
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
