HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 53472
Thin Dense Hard Chrome Supplier Needed
October 28, 2009I am an engineer investigating a coating solution for a precision ground tooth rack (linear gear). Currently we are sourcing this from Japan and use Raydent as the coating. I will be domestically manufacturing these and would like to locate a vendor with a similar coating solution compared to Raydent. Application needs corrosion protection and lubricity. Looking for a local vendor in the midwest. Located in Minnesota.
Jake Strombergprecision automation equipment - Vadnais Heights, MN, USA
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
