53429
Which is a suitable process before painting
[India]
October 22, 2009
Which is a better process to do before stoving epoxy/ enamel
painting - Zinc phosphating or Zinc plating- why?
Thangaraj Vagulabaranam
product designer - Chennai, TN,India
October 22, 2009
Hi, Thangaraj. Zinc phosphatizing is far more common. Zinc plating
has the advantage that you have a true cathodic protection system
under the paint to protect from rust in the event of a scratch or
chip, but it's more expensive and probably somewhat less reliable in
providing good adhesion.
finishing.com
Brick, New Jersey
October 27, 2009
Dear Sir,
You are right,
Zinc Phosphating will be best for this application.
Deep Mathpal
- Greater Noida, Uttar Pradesh, India
October 29, 2009
Dear Thangaraj,
Phosphating is the common [treatment] for before painting, if you
doing the Zinc plating before painting, you will get better corrosion
resistance. if, you are not having any problem in the salt spray go
for phosphating
Kannan B
- Salem, Tamil Nadu, India
October 30, 2009
Hi Thangaraj
What is the material you are going to do painting, steel or cast iron
etc?
Please explain your actual requirement on corrosion and adhesion for
your parts.
If it is cast iron parts you can still have the choice of avoiding
phosphating by replacing regular shot blasting as pretreatment
process for your parts.
But make sure your corrosion and adhesion requirements are
accomplished
Good luck
Vijendran Sudeendran
- Chennai, India
