53409
Which blackening coating to use [Spain]
October 20, 2009
Hello,
I am searching for a blackening coating for low carbon steel that will be corrosion resistant. It will be for steel columns for a mobile pavilion (or stand) which is to be easy to setup and disassemble and with a very low or non existent maintaining; for that condition, simply painting the columns is not an option.
I have read about black oxide coatings which is are not corrosion resistant, and also about zinc and phosphate coatings which are very low corrosion resistant. Stainless steel could also be an option if necessary. The main ends are its architectural quality, that is the "blackness" of the steel and that it be corrosion resistant and wear resistant (though this could be reserved only for some rotating joints which could have a different coating albeit a black one).
Jesus Galvez
Architect - Madrid, Spain
contact button
October 23, 2009
You can use oil blackened stainless steel(oil it very very slightly with linseed oil/then heat it to 300-400 C -- try it on some scrap)),probably stainless can be black anodized too.Black chromium plating can be used too(or clearcoated black nickel).Hope it helps and good luck.
- Zagreb, Croatia
October 24, 2009
I thought only Aluminium could be anodized... Can stainless steel really be anodized or is the black treatment in fact a coating?
Jesus Galvez
- Madrid, Spain
October 29, 2009
There are two ways to achieve black color on stainless steel sheets. Inco and PVD. Inco is dipped and PVD is done in a vacuum furnace at high temperature, with various gases and sputtering targets. I believe PVD coating is a more permanent coloring process than Inco.... based on my information. PVD can be done on glass and stainless steel...not sure if carbon steel will pose to be a problem.
Michael Liu Taylor
   specialty stainless steel distributor
Dallas, Texas
November 3, 2009
Black anodizing for stainless steel:
NaOH........700 gm
KMnO4.......10 gm
Na2S........1 gm
1 lit water
110-120 C temp.,20 v,60 minutes
(according to Handbuch der Galvanotechnik,Muenchen 1966.)
Hope it helps and good luck!
- Zagreb, Croatia
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
