53365
Sheetmetal quotes came in with different
coating applications (Zinc Chromate/Iron Phosphate) [New
York]
October 16, 2009
My project is a sheet metal medical cart. Made out of mild steel
with a powder coat finish. There are areas in which the powder coat
does not cover or is masked from. These areas brought up a concern
for corrosion. As the sheet metal quotes came in I noticed that the
coatings they chose were different. One used a zinc chromate coating
and the other used a iron phosphate coating. The piece price is much
higher now when they added the zinc phosphate. The iron phosphate
just was added without an increase of price. My question is there
that much difference in the 2 processes or just the 2 quotes and will
the iron phosphate be ideal for my need. Like I said before it is a
medical cart that will be shipped over seas. I appreciate any info
you can give me.
Kevin Lutkins
Product Designer - Ithaca, NY
October 19, 2009
It is like a Yugo and a BMW. They will both carry 4 people and go
the speed limit. So which is better. No contest, the BMW is, but it
costs more, so which is better considering everything including cost.
That depends on the use. The zinc phosphate can be a far superior one
in corrosion resistance and in paint adhesion. It is more picky to
run and normally has more QC done on it. Iron can be good and it can
be very poor, depending on who is doing it and the associated
QC.
For your parts, I would go for the zinc, based on salt spray or other
corrosion tests.
- FL
