letter 53317
Shot Blasting of chrome
October 13, 2009
I want to shot blast a metal roll made of HARD CHROME STEEL. Whats
grits to be used and what size to use to get considerable roughness
on the roll surface.
Venkatesh K
Engineer - Tirupur, Tamilnadu, India
October 14, 2009
For better understanding, Shot blast normally means steel shot or
glass bead or possibly cut wire. This has sieve sizes.
Abrasive blasting uses a media like sand or aluminum oxide or one of
the carbides and has grit sizes that equal the sieve that a given
percentage will pass thru.
If you shot blast your roll, it will dent the chrome and very
probably much of it will peel off as it is highly internally
stressed.
If you are going to abrasive blast it, I would use one of the
carbides. 16 grit if you want it extremely rough and 24 or 110 more
likely. Here again, excessive blasting will probably cause it to
peel.
Normally, you would blast the metal roll a bit rougher than desired
and then chrome plate it for a rough chromed surface, rather than the
other way around.
- FL
First of two simultaneous responses -- October 15, 2009
I read Venkatesh's query differently from the way that James
does.
I believe that he has a roll made of a hard, chrome-containing,
steel. Not that he has a chrome-plated steel roll.
If I am reading it correctly, then the fact that the steel contains
some chrome is not important. The only important thing is the
hardness of the roll, because that will affect the necessary abrasive
grit size needed to achieve a given degree of roughness.
I suggest that the term "considerable roughness", applied to an
article of completely unknown dimensions, conveys no real information
at all.
Venkatesh, again assuming I am reading the post correctly, what is
the hardness of the roll, and what roughness do you want?
Bill Reynolds
consultant metallurgist
Ballarat, Victoria, Australia
Second of two simultaneous responses -- October 15, 2009
From what he is saying I think he may be referring to a hardened
chrome molybdenum press or crush type roller like those used to roll
foodstuffs or crush out oils. It may not be chrome plated at all. I
suppose if he could tell us what he is doing with the roller,
EXACTLY! It may make it possible to give him some hints as to how to
go about it.
Rod Henrickson
gunsmith
Edmonton, Alberta, Canada
