53312
Finish for AISI 1095 blue tempered steel -
flat spring application [New York]
October 13, 2009
We are going to be using 1095 sheet material to make a flat
spring. As part of the manufacturing process, we will be putting a
thru hole in the spring as well as shaping the outside. This spring
is used on a medical instrument and it most likely will experience
exposure to a bleach / water cleaning solution (in case of a blood
spill). The spring is used in a latch operation and will undergo
about 4-6 actuations a day when loading or unloading our treatment
kit - so the cycles over life are not that huge (3,000 would be a
high number).
During a design review, the question came up about corrosion
protection on the spring and particularly the edges. The spring
itself is about .125" wide x .75" long x .020" thick. The spring
undergoes about .060" deflection during it's operation and is sliding
over a surface that has an electroless Nickel finish.
The reason we have chosen 1095 is because of it's high yield stress
(>200 ksi). We are operating around 150 ksi max stress.
What options do I have for putting a finish on this part? Is
electroless Nickel and option? There was a concern that the plating
may crack under the deflection stress. I want to make sure I don't
affect the temper of the spring during the finish process.
Gary Hartman
Product design engineer - Rochester, NY USA
October 14, 2009
If exposed to bleach 1095 will rust very quickly. Electroless
nickel, if thick enough (.001" min) will be reasonably rust resistant
and can be expected to flex some.
Make certain that the parts are closely inspected after plating to
verify that adhesion of the nickel is good.
Jeffrey Holmes,
CEF
- Spartanburg, SC, USA
October 20, 2009
Jeff,
Thanks for your reply. I was thinking about Elect Ni but was
concerned about the flex. I will make sure we have a note on our
print to inspect the finish.
Gary Hartman
- Rochester, NY US
