How to do Stainless Steel No4 finish touch-up? [Singapore]October 13, 2009 I would like know how to do touch-up on SS No4 finish if there is
scratches on the surface? Josephine Lim
October 14, 2009 First of all, a scratch is a variation of some surface material. That means that that the surface is uneven along a point or points (line). The only way to eliminate that problem is to change th surface. That means that you must either change that surface or blend in the surrounding surface to minimize the appearance of the points. The best way to do that is mechanically through some abrasive process. The fastest way to do that is with a wheel system; however, that may also mean re-doing the entire surface to blend in the entire surface to a new surface pattern/texture.
October 15, 2009 Well in a way a #4 weight finish is sort of crappy. We see it all the time on stainless firearms and just about every stainless kitchen appliance we use. It is somewhere between 150wt and 320wt depending on whose definition you use. The problem with the finish is that it is fairly easy to scratch or burnish. Light scratches can be removed with red Scotch Brite pads by polishing in the direction of the original finish. Deeper scratches must be polished out with wet and dry paper or cloth with a carrier or lubricant or a mechanical polishing system. Some times just blending is impossible and the whole unit has to be re-polished. Every job is different.
October 23, 2009 Thank you for your reply. Josephine Lim
October 28, 2009 I'm afraid the answer is no. Your best bet is to stay with Hairline finish at least you can remove light scratches with the appropriate scotchbrite pad and sand it in the direction of the grain.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
