Caplugs
 53200
Restore welded stainless plate [Sweden]
September 29, 2009
Hi
We are a company in Sweden that works with stainless steel and we have a problem.
After we welded together two sheets grinded stainless sheets grit 220 we need to grind down weld and restore welded area so it blends in with grinded area. Because sheets are big we don´t want to grind and polish whole sheets with scotschbrite. Today we use a linear grinding machine PTX 300 from Eisenblaetter but it takes too long time.
Hope You can help us with this problem
Best Regards
Fredrik Björn
salesman - Växjö, Sweden
contact button
October 2, 2009
Long is a relative term. Reworking/ blending in welds is probably one of the most difficult aspect of surface finishing and there aren't many short cuts other than automation. There are some chemical processes that can be used to restore a uniform surface, but it won't blend in uneven surfaces.
AF Kenton
Nova Finishing Systems Inc.
Huntingdon Valley, PA
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
