53163
Corrosion of Aluminum cold plate under Propylene Glycol - water solution [Wisconsin]
September 23, 2009
Hi,
We are trying to use Aluminum cold plate, Alumiminum Heat exchanger, Steel pump, steel heater with inhibited propylene glycol water coolant.
What type of corrosion problems are likely to occur at cold plate or HeX that are made of Al. alloy?
How to study the corrosion rate?
Ashu
Ashu Joshi
- Waukesha, WI, USA
contact button
September 25, 2009
Just be aware that corrosion tables are set up by school boy engineers who weigh a piece of metal and immerse it in a pyrex beaker of solution for a period of time and then take it out and weigh it again. That will not work for you. With that combination of metals you mention there are all sorts of opportunities for various galvanic voltages to start corroding something.
Editor's note:
   Mr. Probert is the
   author of
Aluminum How-To / Aluminio El Como
September 28, 2009
Hi,
Indeed, there is always a chance to overlook something or over simplify the corrosion analysis of a system but in your particular case, the combination of fluids and metals are the same present in most modern car cooling systems and they last for years. Propilene glycol is the main consituent of anti-freezers. Aluminum is the metal of choice for radiators and car water pumps are often steel. I would rather focus on other potential areas of problem, not this one.
Guillermo Marrufo
Monterrey, NL, Mexico
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
