HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 53160
COLOR CODING OF METAL THAT DOES NOT ADD THICKNESS
September 22, 2009
Thank you in advance for looking at my question. We have a job that is a simple larger size washer that comes in many thicknesses all made to a strict thickness tolerance. We have been asked to
"color code" the washers with each thickness having its own color. 15 different colors! Quantities range from 400 to 5,000 of each per run. We have attempted to dye the parts with limited success. Do you have another suggestion that we could look into that would be cost effective and not add any thickness to the part? This has frustrated us for sometime now and hope you can help. We are also ISO 14001 and have enviromental issues to deal with.
Tom Bader
Owner metal stamping company - Akron, Ohio, USA
September 26, 2009
There are hundreds of company's that sell indelible inks like the ones used in magic markers. Some are even oil and solvent resistant and I really doubt that you could even measure their thickness with a common caliper. This is one such company. markem-imaje
Rod Henrickson |
First of two simultaneous responses -- September 28, 2009
Are the tolerances tight on the faces only? How thick are the washers, i.e., could you color code just the rims?
Jim Treglio![]() Lakeside, California |
Second of two simultaneous responses -- September 28, 2009
If washer thickness is the main concern paint the O.D. or I.D. or both. Use the most suitable ink for your purpose regardless of its thickness. Another option would be to lightly acid etch or sandblast every part through a stencil. These opertions do not produce raised bumps. G. Marrufo-Mexico
