53123
Seeking hard chrome plating and finishing
for hydraulic piston/rod made of ductile iron [Canada]
September 18, 2009
One-piece piston/rod considered to be cast of ductile iron in
order to save production cost. The part weight is about 10kg,
dimensions: Ø225x35mm (piston) and Ø100x55mm (rod).
Chrome required to provide proper finish for seals application and
corrosion protection for exposed portion of the rod.
QTY=100 for initial order.
Igor Berliant
MFGR - Delta, British Columbia, Canada
