52981
Why bronze needs cosmetic chrome/nickel
plating? [Missouri]
August 26, 2009
My company purchases a porous bronze part that once is assembled,
in the field will be exposed to moisture and water (sometimes salt
water) 24/7. The plating is part of specs on the drawing from early
1960s. I have asked the bronze mfg company for the reason(s) and he
refers me to the specs on my own drawings. I have exhausted all
avenues to find an answer to the need for plating, where bronze
itself is used in marine applications as one of the best corrosion
resistant alloys.
Please advise.
Michael Modjallal
customer - St. Louis, MO, USA
August 31, 2009
It is my understanding that bronze will oxidize if not coated with
some thing or polished as required.
You might get by with dipping it in a thin hot wax to fill the
pores.
It is your spec and someone in the past thought that the plating was
required.
One way to find out is to give several unplated parts to select
customers with no liability attached to see how they work out in the
real world. If you find out that you can skip the plating step, it
will not take long to recover the price of the give aways.
I suspect that some of your customers prefer the look of the plated
part.
- FL
September 3, 2009
There are two issues at hand. First, this porous material is used
to drain water due to condensation in electrical boxes; dipping it in
wax fills the micro gaps and can not drain water. Second issue is
that when archeologists discover bronze statues several thousand
years old, they are intact and at worst a slight greenish film is
seen on some parts of them. So, Bronze is not like steel that is
eaten up by oxidation. It is an everlasting alloy, more like
aluminum. Aluminum is not plated for outdoor use. The question comes
back to "why it was recommended to nickel plate this alloy?".
Thanks for your info,
Mike
Michael Modjallal
September 3, 2009
Hi. I think the answer lies in the word "cosmetic" in the original
question. Bronze is/was often nickel-chrome plated. For example, all
kinds of cleats and stuff for boats have been nickel-chrome plated
bronze.
Bronze is much easier to reliably and durably electroplate than
aluminum or stainless steel, and the aesthetic durability is far
greater than electroplated steel. When the nickel begins wearing off
of bronze, it still looks and acts great, whereas when the plating
wears off of steel you have a real mess.
finishing.com
Brick, New Jersey
October 7, 2009
FYI, bronze does corrode when exposed to corrosive environments.
Hard or salt water can corrode bronze pretty quickly. I do sculpture
restoration and see these effects on bronze all the time. Aluminum,
when used outside gets an outdoor rated anodizing. If your bronze is
going to be exposed to salt water, you should make sure you having
your bronze cast in Naval Bronze. As for plating, I think that is
just a cosmetic choice, although it would help protect the bronze,
but it too will also start to break down in a few years. Good luck!
Dan Romo
- Oakland, CA
October 9, 2009
Dan, the product Michael is having trouble with is made of
deliberately porous bronze so that water will drain through it, as
explained in his second post. Using a sound material of any type
would completely block (no pun intended) that property.
Michael, there are powder metallurgy techniques (essentially where
powdered metal is compressed to a shape and then sintered at a
temperature below its melting point) which could give you controlled
porosity in many different alloys. Cost will be a big factor in
considering that route, though.
Bill Reynolds
consultant metallurgist
Ballarat, Victoria, Australia
