52763
Need Cad plating and Aluminum IVD of test
coupons [Florida]
August 3, 2009
Hello,
I'm in need of a price quote for plating of the test coupons type 1d
(notched C-ring) detailed in ASTM F-519. The details are listed
below.
48 samples at each of the following:
1) LHE Cd Plating-The LHE Cd plated specimens shall be plated all
over following QQ-P-416 Type II (with supplementary chromate
conversion coat applied after bake), Class 2 (0.0003 to 0.00049 inch
thickness).
2) LHE Cd Plating with Bare Notch Area-The LHE Cd plated specimens to
be tested with a bare notch area shall be masked and then plated in
accordance with QQ-P-416 Type II (with supplementary chromate
thickness). Masking Prior to Plate-The notch and approximately ¼ inch
on either side of the notch shall be masked to prevent Cd
deposition.
3) IVD Aluminum coating following Mil-DTL-83488D, Class 2 type II
coating.
If you have any questions, feel free to call me.
Thank you so much!
Jane Pitchford, Project Engineer
consulting - Jacksonville, FL, USA
