52754
Coil anodizing needed - unless you've got a
better route. [California]
July 31, 2009
Hello Everyone,
I've got a situation where coil anodizing (reel to real, continuous
tape, etc.) seems to be the proper solution, and I'm looking for a
job shop that can help me out.
Our ultimate goal is to use anodize to act as a non-conductive
barrier on the inside of a part that is roughly shaped like a funnel.
The part itself is about 1/2 inch by a 1/4 inch and the aluminum is
similar to a heavy foil - 0.004" thick. The anodize that we are
looking for would be a standard Type II class 2, preferably dyed gold
using FAO and sealed in nickel acetate.
The alloy hasnıt been decided on yet, and we would be absolutely open
to suggestions (not being overly knowledgeable about coil anodizing,
Iım not sure which alloys do the best in terms of being able to shape
or bend slightly AFTER anodizing &endash; which always trips me
out).
Being a huge proponent of bulk anodizing, I thought about going that
route - but the parts are just too thin to live up to the conditions.
So, in the interest of trying to find the next cheapest alternative,
we are now thinking about going with coil anodizing and following one
of two paths:
1) shape the part but leave it on a 1 inch wide tape (four abreast)
(ultimate length to be determined, unimportant to needs - could be
anything from a few feet up to hundreds of yards. Open to
suggestions.), anodize it, punch it out for use.
2) get the tape anodized, then shape and punch (I'm betting this
option wouldn't work - I think that the stretching of the metal would
cause the anodize to crack too much to be of use).
Of course, like I indicated in the header, I'm also completely open
to suggestions. The primary goal is to have the inside be
non-conductive, the outside be pleasant visually (it will be visible
to the end user), and the coating to be CHEAP per piece.
Any thoughts, suggestions, or quotes?
Thanks - Jim
Jim Gorsich
Electronics Manufacturer - San Diego, CA, USA
