52311
Corrosive air in our new office? [New
York]
June 3, 2009
My office recently moved about 15 blocks from its previous
location. Within a week or two we noticed that all our steel tools
and products were rusting. We don't understand what could be that
different between the two locations. Both offices are located in
Chelsea, NY very near the Hudson River. The corrosion also seems to
be seasonal, increasing significantly in the summer months.
Thanks for any insight!
Evan
Evan Abel
Product Designer - New York, NY, USA
June 4, 2009
Hi, Evan. If your office is a free-standing building, I don't have
any ideas. But, if not, I would think that something that another
tenant is doing is causing the problem. Hydrochloric acid, for
example, is horribly corrosive and it is not really a liquid, but a
gas dissolved in water. If fellow tenants are a plating shop, a tile
shop, a chemical mixing facility, or anyone who uses acid for
anything, that could be the problem. Don't even think about letting a
maintenance company acid wash a floor or anything else.
finishing.com
Brick, New Jersey
August 3, 2009
Hi Neil,
The corrosion you are encountering is caused by contaminants and
could come from a number of sources. As example, there is a major
problem in FL where the sheet rock was made with sulfate contaminated
water. Now it is exuding acid fumes and corroding everything.
Location can matter too. If your building is down wind from a coal
fired power plant contaminants can be entering through the
ventilation system.
I suggest performing testing on a corroded surface for chloride,
sulfate or nitrate contamination. There are other sources but these
are the most common. Once you identify the contaminant then search
out the cause.
Jim Johnson
- Chandler, AZ, USA
September 14, 2009
dear sir.
the above problem is purely there is an acid cleaning factory nearby
and it is periodically releasing HCl acid , which is used for metal
treatments for corrosiveness. the chemicals used are not neutralised
before they are released to atmosphere.
at times there is a failure in the neutraliser and acid fumes spread
in the atmosphere.
also some nearby metal treatment unit is doing a pickling operation
for softening the metal before pressing or forming. you can fix a gas
detector which will show immediately presence of acid fumes.
with warm regards.
B. Manickavelu
- Banglore, India
