52089
Passivation tank made of 304SS failed in a
week
April 29, 2009
We have a new stainless steel tank (304). We used this tank to
passivate stainless steel parts. The composition of stainless steel
passivation solution is 30% by volume Nitric acid and 2-3 Lbs./ gal.
sodium bichromate. After processing 1 week, tank starts to
leak.
Please help.
Vijay Kansupada
Regulator - Columbia, SC, USA
May 14, 2009
Vijay,
A very important question: Where did the tank begin to leak from? A
weld? A fitting? A new hole that appeared?
Gene Packman
- Great Neck, NY
May 15, 2009
I'll bet it failed right adjacent to the welds. Carbide
precipitation in the grain boundaries. Next time use 304L, or better
yet, a lined tank.
Jeffrey Holmes,
CEF
- Spartanburg, SC, USA
May 28, 2009
Hello,
SS Tank is costlier.A cheaper and a better alternative is a high
density PP Tank(Thickness of PP depends on the volume of the tank)or
a MS Tank lined with a 10mm PVC or PP lining.
Subramanian
Ramajayam
plating chemist
Bangalore, Karnataka, India
June 23, 2009
Hello Vijay,
316L is a better choice.
Check for proper grounding.
Good Luck,
Micheline Forth
Micheline Forth
- Rincon, Ga, USA
June 24, 2009
I have used rotational molded medium density polyethylene tanks
that were supported with either stainless beams for large tanks and
enameled wood for smaller tanks with great luck. They cost less and
are less likely to fail especially if the welder was poor.
- FL
July 8, 2009
Hi Vijay,
The suggestions by others to use moulded hdpe tanks makes eminent
success.
No,but no welding of the Pe tanks ... use tank adaptors ...
otherwise due to the nitric you'll get stress cracking at the weld
areas.
Cheers from White Rock Freeman N.
Freeman Newton
- White Rock, B.C. Canada
