52085
Flash Hard Chrome Plating - Clarification
April 27, 2009
Dear Sir,
Am a process engineer (Machining), in one of our drawing I came
across a note stating ID & face of a flange bore should be "Flash
Hard Chrome Plated Polished Plating to a min case depth of 25
micron".
Kindly clarify:
1)What is Flash Hard Chrome Plating.
2)Whether the above stated plating can be done by normal chrome
plating process or requires a special process?
Awaiting for your reply.
With Regards,
Yogeswaran Shanmugam
Process Engineer (Machining) - Chennai, Tamil Nadu & India
May 13, 2009
Hi, Yogeswaran. "Case depth" doesn't sound like appropriate
terminology to describe chromium plating; and 25 microns hardly
sounds like a "flash". Although it sounds like plating that would be
done from a conventional hard chromium plating bath, frankly, it
sounds to me like a spec written by someone who isn't very familiar
with the process.
finishing.com
Brick, New Jersey
