52084
Black Spot Problem
April 27, 2009
Hello, I have a problem about electroplating: I have plated the axle wheel at my supplier but there are black spots on the surface of product especially on the shank area.
I have checked electroplating parameter and there is no problem with them but i am suspicious with rinsing water condition.
Test result shows : degreasing water rinse => TDS:521~617 ppm, pickling water rinse=>548~4710 ppm, electroplating water rinse 540~2270 ppm & chromating water rinse 513~516 ppm.
Based on the water rinse data, do you think our rinsing quality is proper enough ? is there standard quality for water rinse of electroplating.
Regards Yudi W.
Yudi Wahyudi
Engineer - Jakarta Utara, Jakarta, Indonesia
contact button
May 13, 2009
Hi, Yudi. You have not told us anything about your plating process to enable anyone to advance the alternate theory that it is a plating problem. Low quality rinse water can cause many problems, but "black spots" doesn't sound like a likely one to me. I suspect the black spots are iron contamination of the zinc plating bath. Please tell us about your plating process.
finishing.com
Brick, New Jersey
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
