52057
Help needed with identifying metal plating
and process
May 7, 2009
Hi, I am a student working on a product teardown for a product
design class. We are pulling apart a VS Sassoon Quietone 2000 hair
dryer. The outer shell is marked as ABS, but it seems to be coated
with a metallic plate. It looks like black chrome, but when scratched
reveals a copper colour. It is thick enough to peel off... about the
thickness of aluminum foil. How has this been manufactured? Do you
think this is electroplated or is it plated through PVD?
Matt
Matthew Baker
University student - Brisbane, Queensland, Australia
May 8, 2009
Hi, Matthew. Good work. I don't have inside knowledge, and what
you have detected so far is not really scientifically conclusive, but
it's enough to hazard a guess that it's copper-nickel plating. Hard
to say if it's actual black chrome on the outer layer on top of the
copper and nickel layers.
The sequence is probably approximately: etch the ABS for tooth,
dip in palladium chloride, dip in tin chloride, electroless nickel
plate, copper electroplate, nickel plate, black chrome plate. Good
luck.
finishing.com
Brick, New Jersey
