HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 52052
Need solvent for wax dissolution from silver idols
May 6, 2009
We are silver idol manufacturer in india by electroforming method. After completion of silver forming we are struggling to remove the wax. Nowadays we are removing the wax by heating method. But we cannot remove the wax completely. Anybody can tell to completely remove the wax from silver metal.
Anbu ManiProduction supervisor - India
First of two simultaneous responses -- May 8, 2009
Immersion in boiling water will soften most of the wax and make it float. Addition of ammonium sulphate to increase the water boiling point and density might help.
Second of two simultaneous responses -- May 8, 2009
In the old days, many used chlorinated solvents. Caution! the part must be dry or the solvent becomes acidic. (bad for silver)
James Watts- Navarre, Florida
May 29, 2009
There are solvent based Wax strippers such ethanol and d-limonene.
The first is more dangerous.
Solvents can be recycled using a solvent distillator.
Gabriel Schonwald |
June 1, 2009
Have you tried White Spirit or Turpentine, used hot the wax will dissolve in these. Reclaim solvent by distillation.
Terry Hickling Martex Paints Ltd Birmingham, United Kingdom |
September 11, 2010
Hi Mr. Anbu,
We are a silver electroforming company as well.
Wax is notorious to remove from a silver electroform, solvent will prove very costly. While removing wax thru direct heating method there will be probabilities of the electroform cracking and result in a damaged piece which cannot be sold.
Try put the wax filled electroform over a hot plate with controlled temperature you will have to make sure that the silver is not overheated otherwise wax will find its own way from other areas which dose not have access to the outlet.
Needless to mention that you will have to drill few holes at the bottom for wax drainage and air escape.
This is what we do.
- Bhavnagar, Gujarat, India.
