Caplugs
  52050
Outgassing anomalies caused by plugs?
May 5, 2009
Greetings, Is the length of the masking plug important? In other words; if the length
of the masking plug for a hole is too long will it interfere with or cause excessive
outgassing thus leaving the surface around the hole with a contrasting appearance?
Carl Johnson
manufacturer - Manteca, CA, USA
contact button
May 8, 2009
In some, but not all, the excess plug interferes with the solution flow from whatever agitation method is used and causes the plating to be less in one or more quadrants around the hole. Heavy build hard chrome is very much bothered by excess plug length.
- FL
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
